cant get vcds prog to run
ive downloaded the ross tech program but when i run it when pluged in i cant get past the test port option you have to do at first, problem with usb interface with a error code.can anyone help?
Uploaded with ImageShack.us
Edited by Joe67
What lead are you using?
Did you do the test with the ignition on?
added a screen shot to first post
You need the correct drivers for your fake cable. Did you contact the seller?
(you wouldn't be having these issues if you'd bought a genuine cable!)
i was told in another post on this forum that cable would be ok,hence why i bought it
There is no problem with the cable you bought. It is NOT a fake cable - it is just a generic for use with VCDS-Lite.
My guess is that you have set the port option to USB. Take a look in device manager to see what serial port Windows assigned it and select that serial port.
yes its set to usb mate as thats what am using,have tryed the other usb ports.am not totaly sure what you mean, com1 com 2 etc?
Edited by Joe67
Yes, Windows will assign a COM port to your lead. You could just try all the COM ports.
i did ,com 2 and 3 said port ok but no interface port 1 and4 said no port and no interface
Windows has probably assigned a COM port greater then 4. What version of Windows are you using?
Try right-clicking the My Computer icon and select Manage. Click on Device Manager and expand ports. What port is assigned to your lead?
ahh the usb ports use 5-6-7 i think :D (seen that in pop up there when connecting the lead to car again.)the laptop has ****ty vista
Edited by Joe67
should i be using lite instead??
i seen this
The full (non-Lite) version of VCDS is not compatible with 3rd party interfaces at all, even in shareware mode
Edited by Joe67
Yes, your lead will only work with VCDS-Lite.
lol what a dafty!
ok one usb port uses com4 :D
got it to work now just need to register,thanks!
it was scaning and said needed to reg
It needs to be registered to do an auto-scan. You can open a module (e.g. Engine) and click on Read Fault Codes to get the fault codes for just that module.
alrigth lads thanks for the help,no codes found now i need to figure out why the engine is so weak..ill go back to other thread.
Edited by Joe67
ah, the beauty and simplicity of buying the full licensed version. :D
@Joe67 - you might take the time to read the online manual for VCDS-Lite. It explains how to do things with the tool.
Also, take a look at the FAQ section of the website. There is all sorts of useful stuff in there. If you do need to register, your money isn't wasted. If you look at the upgrades section, you will see that you always have an upgrade path.
