17574 System Too Rich
Hello
I have this error that keeps coming back and my Engine light is ON.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 036 906 034 BK
Component and/or Version: MARELLI 4LV 3335
Software Coding: 00071
Work Shop Code: WSC 59773
Additional Info: TMBND26Y113103186 SKZ7Z0Y0561044
Faults Found:
17574 - Long Term Fuel Trim Additive Air Bank 1: Range 2: System too Rich
P1166 - 35-10 - - - Intermittent
At this links I put my analysis using VAG-COM...
http://rapidshare.de/files/1106898/diaginfos.zip.html
http://rapidshare.de/files/1145329/LOGS_Radu.zip.html
You have to scroll down and choose FREE download... that is the way they use it... I had no other way, I do not have a place where to upload the files :-(
Any ideas? Is Lambdasensor gone?
What should I check and where (using VAG-COM) to detect that?
PLS HELP
Thank you
Radu
Clean the throttle valve and reset the throttle chamber and the problem should be gone
rvacaru, please let us know if that fixes you problem, and thanks for the advice, Netnavi.
I have already cleaned using a good spray the Throttle valve...
I suspect oxygen sensor... I have VAG-COM logs... voltage is not variable between 0.2-0.8V, but ONLY around 0.438 V !
Radu
Nobody that looked to my logs is able to tell me if my oxygen sensor is gone?
Today the Engine light came again on, same error :(
  • 4 months later...
Problem fixed.
Timing belt was mounted wrong...wrong timing... done by Skoda Service....
