VCDS Scan
Did a VCDS scan earlier and found a few fault codes. I have done a bit of research about what each one means but wondered if there are any obvious things to check to rectify the faults.
Any info appreciated.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2EF5EFB943F
1 Fault Found:
00898 - Control Circuit A/C compressor
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 26042
Shop #: WSC 13765
VCID: 3C7330C306FB
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 01 AIRBAG VW51 08 0008
Coding: 12337
Shop #: WSC 13765
VCID: 2C530083F69B
1 Fault Found:
00532 - Supply Voltage B+
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 3B0 035 186 D
Component: Radio BNO 0102
Coding: 00407
Shop #: WSC 13765
VCID: 204BE4B38A53
1 Fault Found:
00853 - Loudspeaker(s); Rear
36-00 - Open Circuit
I'd clear them, and scan again in a while, see what's returned. They're the ones to worry about.
No idea off hand on how to fix them - the Ross-Tech website is a good place to try if you haven't already.
Intermittent are usually just that. The A/C one was probably triggered by the low voltage dip which brought up the other two. It does sound like a back speaker is dead / not connected though.
Thanks for the replies. I did as suggested and cleared the codes and immediately the Air/con and Speaker faults returned and I am pretty sure the air con wasnt getting too cold and it was re-gassed a month ago.
Anyway I cleared the codes again and went for a 20 minute blast and then scanned again.
Now the aircon fault hasnt returned and it seems to bee getting cold so I am guessing thats the intermitent part.
The speaker fault is still there but I am not so concerned about this at present.
However on the last scan 5 minutes ago it bought up 01598 code again but with a different description.
I am thinking that this fault is the root cause for the other intermitant faults I am getting.
Any help really appreciated.
Coding: 26042
Shop #: WSC 13765
VCID: 3C7330C306FB
1 Fault Found:
27-10 - Implausible Signal - Intermittent
Alternator sense wire or a battery on it's way out!
Thanks for the really quick reply.
Bought the car in October and seller said battery is new (looks new too) so I think I can rule that out.
Will check the sense wire I think thats pretty common as I have seen it mentioned in a few posts.
Would this be the wire your refering to just so I am looking at the right part
http://www.seatcupra...ad.php?t=209472
That's the very fellow!
Almost a given that it'll break at some point!
Had a look this afternoon and there doesn't appear to be a break on the wire but I need to have a better look.
However there is a brown connector located very near the black connector of the Sense wire and one of these is broken, anyone know what this brown connector is for.
