A couple of little things fixed
I have had a couple of issues. Firstly one sidelight bulb out. Very easy fix 50p bulb from my local car spares shop job done. Next I've had a leaky washer bottle for the last couple of months. Hasn't bothered me as car spends all week locked up in garage but I thought I'd investigate today as the warmer weather is on its way lol. So out with the bottle quite easy just two plastic nuts to undo made easier by firstly removing bolts from charcoal canister( I think that's what it is ) And moving canister to gain access to water bottle top fixing nut. Then electrical connection to pump and front and rear hoses removed and out it comes.The bottle was undamaged however the pump was quite loose in the rubber seal in the base so maybe this is where my screen wash was escaping from.Back down to the local car spares shop to purchase pump and seal bargain at £10 (genuine Skoda pump £32 ouch ! ) then back home to re assemble and test. After assembly front washers all ok but nothing from the bidet(rear wash wipe) oh no I thought broken connection somewhere between front and rear. On closer inspection it was just a blocked rear nozzle and once cleaned out with a pin all is well. All in all a productive Saturday mornings work and I can see clearly now.
Always nice when its an easy fix.
