Daylight running Lights
My Daylight running light have stopped working and can't find any ref to a fuse in the manual.
does anyone know what number the correct fuse is,
I have tried switching them on in the MFD but stiil not working, any info would be gratefully appreciated.
Checking electrical scheme they are wired on the "Onboard power supply control unit", but i couldn't find under which fuse.. if there is one dedicated for DRL..
There isn't a dedicated DRL fuse. The problem must lay elsewhere...
Did you try to switch them off then on again on MFD? Once a friend of mine had a similar problem with auto-lock feature. It was already enabled but it didn't work, after disabling and then enabling again it worked fine
Good advice. By MFD I assume you have Maxidot?
You should also try enabling them using the indicator stalk (detailed in the manual for cars not equipped with Maxidot)...
True. I forgot you can enable or disable them with indicators too. Maybe you did it by mistake (though i think it should reflect it on MFD/MaxiDot)
Edited by fabio978
Thanks for all the advice/tips Think I might have to take it to a main dealer because I tried all the things you have suggested.
anyway thanks again.
