would a 2008 Fabia II 3 have can-bus multiplex wiring
hi i was wondering if my 2008 Fabia II 3 have can bus / multiplex wiring,as i am looking to fit a tow bar and not sure if i will need a bypass relay?
cheers
cheers
I'm sure all Mk2 Fabias have canbus.
I am pretty much sure all vehicle's 55 plate onwards have canbus wiring
  • 3 years later...
Hi, I have a September 2014 fabia tried fitting a VW rns315 2015 with Bluetooth, everything seemed to work although the ignition didn't control it, I went away fir five days and came back to a completely flat battery. Is this just a coding issue or do I need a different can bus connection?
I returned that one and am trying to find more definite info,
Thanks for reading,
Mike
cheers
Yes, you definitely have a canbus, as others are indicating.
Thanks for reading,
Mike
It's not polite to hijack someone else's thread. Especially when you already have your own open.
Sent from my SM-N910F using Tapatalk
