Wheel alignment options
I'm looking forward to picking my Octavia on Wednesday next week and I wondered what options there are on the car for wheel alignment adjustment? I've read that some people have had issues with the factory settings for the geometry so thought it might be an idea to at least get mine checked.
I just called my local RSR Tyres (recommended by another member as they apparently use the Hunter 4 system) and they said the check would be £15 and then about £30 for the front and the same for the rear if they needed changing. He mentioned however that he thought only the toe was adjustable both front and rear though all I told him was that it was an Octavia, not any other details.
Any thoughts?
My guy is free to check, camber can be changed too, mine was fine till I had it lowered, friends new FL was out
Rear camber can be adjusted on new Octavia's. Other then that toe adjustment on front and rear.
Thanks for the replies guys.
Octavia vrs.com lists new settings for the mk 2 models just had mine altered today ....!....to try and stop the inner tyre wear
