Bluetooth Issue
I've fitted and coded my OEM Bluetooth kit as directed on Octavia-vrs.com. The fitting went smoothly (apart from getting all the wiring behind the HU).
Kit before fitted
My phone (BlackBerry 9800) connects to the Bluetooth Automatically and can be used for calls providing I use the phone for dialling/accepting calls, the call itself runs through the Bluetooth. When pressing the Phone button on my Columbus it just mutes the sound and doesn't give me any options.
A VCDS scan shows the following
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 191210F2000269
Coding: 350000
Shop #: WSC 73430 790 00000
VCID: 30640D8F6338723
4 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 219
Mileage: 121335 km
Time Indication: 0
Date: 2000.00.00
Time: 14:01:07
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 121335 km
Time Indication: 0
Date: 2000.00.00
Time: 13:55:35
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 219
Mileage: 121335 km
Time Indication: 0
Date: 2000.00.00
Time: 13:55:35
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 5
Mileage: 121335 km
Time Indication: 0
Date: 2000.00.00
Time: 13:55:31
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H05 2764
Revision: AB001001 Serial number: --------------
Coding: 000004000001000000
Shop #: WSC 73430 790 12345
ASAM Dataset: ------------------------- ------
VCID: 2E5813F7790C643
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 140
Reset counter: 221
Mileage: 120184 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:46
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 212
Mileage: 121184 km
Time Indication: 0
Date: 2000.00.00
Time: 11:43:05
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 221
Mileage: 120184 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 212
Mileage: 121184 km
Time Indication: 0
Date: 2000.00.00
Time: 11:43:05
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 C HW: 5P0 862 335 C
Component: FSE_2P5x H24 0100
Revision: 00000001 Serial number: 00000000543630
Coding: 0000422
Shop #: WSC 24006 576 00000
VCID: 336E0283522E49B
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 219
It would appear I have several faults of which didn't exist before the fitting of the bluetooth kit. The Nav/Radio work fine
Matthew
