mk1 octavia vrs boost then no boost then boost in same gear
hi just bought a 51 plate vrs today for me missus and its great , love it apart from theres a fault with it doh !!
when driving noticed more in 2nd 3rd but happens in every gear when the turbo comes in it pulls then hesitates then pulls then hesitates then pulls and it does this all through the gear about 4 times when it pulls it pulls really well , no warning lights on and apart from this runs really nice please please help
Is your car mapped ?
Sounds like the coilpacks, all then nothing. Have they been done on the recall? Call your local Skoda dealer and ask. Or see the other thread.
hi thanks peeps car is standard , not heard about a fault with coil packs ???? what do i need to do will they still do that even tho its 10 years old ???
thanks again for your help
do you think it could be a boost leak
dont know if this makes a difference but the car doesnt loose power it just doesnt get a full delivery of boost it gets a bit then a bit more the a bit more then a bit more then change gear
Recall will cover your car as long as you have OEM coil packs.
Do a search for coil pack recall.
thanks matey i will have a look do i just ring skoda and give them the reg ???
That's what I did.
Spoke to Skoda today there is a recall but checked the coil packs and 1 has no numbers on it they have been ground off one has been changed 1 is a Bosch unit and 1 has a letter on that needs changing what do you think Skoda will do with the others ? Cheers
Officially Skoda will only replace OEM ones so hopefully they'd give you the benefit of the doubt and replace both the one that needs replacing and the one with the numbers missing. If it was me I think I'd stump up the extra £60 and get them to put 4 of the latest type in. If you disconnect the coilpacks one by one with the engine idling you can tell which one is faulty because disconnecting it won't make any difference to the sound of the engine.
Ah I see I'm not sure if the coil packs are the problem the car doesn't have a misfire and runs really well it's just seems like maybe there a boost leak I could be wrong as I havent had anything to do with this engine before
Might be the boost, the only way you can know for sure is get VAG-com or a fault code reader on it. You can buy them yourself or find someone on here local to you that can do it. Then log actual vs requested boost while you take it for a drive. Likewise VAG-com should show a fault code if there is a problem with one or more coil packs. Judging by the fact you've got a weird mix of coilpacks its had coilpacks problems in the past
sorry whats vag-com ???
Does this happen when you are giving it full beans, its not the traction control dumping boost is it?
You sure it is not mapped? It sounds like the good old surging problem.
VAG-COM is a diagnostic program for VW/VAG cars. Loads of stuff on the forum and internet about it.
Also there are plenty of other diagnostic programs that work off your phone or PC. Bluetooth adaptor is about £10-15. And the programes are a similar amount.
Hi defo not remapped and it's the same in 1st or 5 th tried it with tc on and off , just had a mate come round with a computer and it's come up with a fault code 17705 which is intermittent boost pressure loss between turbo and inlet I think so I will have to have a look at me boost pipes etc
