Smoked effect headlight cluster
Does anyone know what I could expect to pay for some monte carlo style smoked headlight clusters fitting to a mk2 vrs??
This was being discussed last year when news of the 'black pack' came out. iirc i belive about £450
Cheers..... I'll use a well known search engine and make a search for that.
super skodas where you want to go....
ddint somebody tint their original ones and they looked rather good, be a lot cheaper too if thats important
Yes, Hayden did his VRS and it looked pretty smart in the end. See if I can find the thread.
Heavy operation pics
Rip off! Skoda dealers are around £100 each and here they are £93
http://www.skodaparts.com/product/fabia-headlamp-n-s-black-2011-2013-50079
http://www.skodaparts.com/product/fabia-facelift-headlamp-black-o-s-2011-2013-50080
Here it is:
http://www.briskoda.net/forums/topic/225781-headlight-tint-part-2/page__p__2655650__hl__headlight%20tint__fromsearch__1#entry2655650
although I took them off last weekend as the edge had started to come away with jet washing the car. It was only on one so a shame, but i've ordered so more stuff to have another go.
Thats a fantastic job mate! Did the headlight seal up ok after it?
I remember peeps doin' this sort of thing to their Yaris headlights, to look like the Tsport! Warm up the lights in an oven (Carefully) Split, paint, reassemble with sealant and Bob's your auntie's partner!
I have also spotted film that goes on the front of the glass, similar to window tint film, that you trim, fit and forget (Hopefully) For a fraction of the cost and less overall work too! You may even find you get enough to do the fogs/spots!
Edited by mrgf
Please tell that those are Depo cause when I tried to open a Skoda original it simply didn't want to open.
aim having my fronts&back lights tinted by mint car enhancements of nottingham check them out its worth a look pete
If you choose the right product for re-seal no problem.
Original Hella :D
Put them in a oven at 100° for 10 min. Than you can easily remove the polycarbonat cover. Immediately clean the old seals when still molten. Heat gun works too, but more messy and time consuming.
For re-assembly I use black silicone, I've a pictorial guide for this application, I can upload here on Monday ;)
Before any matte black spraying be sure having the surface wetsanded (about 1000 grit) and cleaned
Edited by irfant
What can I sa
Original Hella :D
I'm so confused - when I tried to open the Hella headlight as you mention I popped it in the oven thinking it would be the quickest thing and even at 100 degress for 15min did not do the trick. Eventually and out of curiosity I left it in at a higher temperature and for longer - the result was parts of the headlight to melt but the seal just didn't want to soften and come apart. Then I tried the heatgun process - nothing! At the end I dropped the whole project until I found out Depo aftermarket Fabia headlights. Those where so easy to open with a heatgun cause the seal was clearly a different type. After 5 mins around the edge with the heatgun and the headlight pop opened with not problems at all. So easy.
That is why I'm so baffled with your Hella headlight pics. Are you sure they are Hella? only way to tell the difference with the Depo ones is the embossed mark of Hella's logo at the back. Otherwise they are exactly the same!
What can I sa
It is Hella
But I guess some batches are different, noticed it from the colour of the seal.
If someone need stone-hard sealing, I can recommend Polyurethane Black Mastic
After sealing, immediately use couple of clamps for proper joining
I guess I probably got my hands on a batch that was glued together with cement! :rofl:
hi think i stick to the tints on the lights but thats me
They Look good :)
i like the bonnet bra how much are they. also how much are the lightsas well thanks pete
