knocking on gear change
Had my fabia vrs for a few weeks now and ther is a knocking noise when i change gear particularly between 1st ,2nd and 3rd gear any ideas what it could be. Im hoping its not the gearbox the car has only done 75000miles
dog bone ?
Ok im quite new to this so what do i need to do to find out if it is the dogbone and i take it there is one on tye right and on the left of the car
Just one, in the centre underneath at the back of the engine, remove the undershield, undo the holding bolts, remove & replace and tighten up.
DB.
Ok how do i no if it is this making the knocking noise or have i just got to change it ajd hope that it cures it
Remove it - if there's a lot of play in it... Then it's more than likely this.
You can either replace with stock, or get uprated bushes for it - but be prepared for plenty of cabin vibration if you do.
Ok ill check it over the weekend. Cheers
Yes, use the standard part from Skoda if you want to be vibrationless, otherwise it's a harsh ride.
DB.
Just ordered new engine mount of ebay £36 hopfully will sort problem
part number was 6q0199851at
