bov help
Calling anyone who has removed the standered bov...... How the feck do you get the bottom torx bot holding it in out? Its in the least accesible place ever :(
Urgent help needed
Do you mean the lower torx bolt here mate?
Got that done now mate had to use an allan key
easier to remove inlet pipe to access it
I had removed nearly every pipe you can see in that picture and still couldnt get at it, had to go get a long allan key in the end
Then the 2 self tapping screws for the solinoid were an absloute pain
oh i found it easy on mine just removing the last section of inlt pipe. the pain was removing manifold pressure sensor
What about the screw to put it back on? I was sturggling to turn the screwdriver for the last few turns and it was still fairly loose
that's coz it weedy stu ;) lol you shoulda brought it down to me :D lol
Il have you know im shall we say not the biggest? For a reason, and its a reason that involves smashing in faces :D
Plus you would have used a stanley blade and a pry bar to fit it if it was anything like you modding my intake :giggle:
I'm still bigger n ur intake is a work of pure artistic genius (with the equipment I had available lol)
pikey mod god! :D:rofl:
