Idle funny and smell of fuel.help!
I've had a new throttle body about a month ago.was running spot on.I've gone out last night and it's spluttering and the smell of fuel is terrible.no warning lights on either,temp is staying as it should.can anyone help??thanks
Coolant temp sensor? They are dual channel so even if the gauge reads right they can be giving the ECU wrong readings. If you have a copy of VCDS you can see what the readings are, also you can do a lambda log to see if there's a vac leak at idle.
Or the other thing is a failed coil pack but it would drive really badly not just idle badly and would throw a fault code.
It's had a temp sensor just before I fitted throttle body.will get it plug in diagnostics.hopefully will tell me.ive also put some injector cleaner in.thanks for help need it sorting puts me on a downer.
was it a genuine temp sender? aftermarket ones have a habit of failing after a few weeks
No don't think it was genuine.would you suggest doing that first.it so weird bin fine then all of a sudden gone crap.smells so rich.
Changed temp sensor again and a still no good.ive changes spark plugs to,still no different.so goin put it on diagnostics today.if its the coil pack will it come up on the machine?I really need this sorting!lol.
Check and see if you're down for the coil pack recall just ring your dealer with your reg number
All sorted split in a pipe.just need to purchase but being bank holiday im a bit stuck.plus don't really no what the pipe is classed as?it goes in between engine and inlet.its a hard plastic one visible on the top.any clues??
Check out ebay for silicon breather hose 1.8t one of them should be it m8
You have been a great help cheers
