WIPERS! Interior Auto/Rain Sensor,Fault codes....
This is driving me nuts now, I drove back from london to manchester on thursday and when i joined the M6 from the M1, for the whole 98 miles on the M6, my wipers did not switch off! they went from hurricane mode to slow mode and not a cloud in the sky!!! And yes the wiper stalk was on off, the thing is,the only thing that works on the stalk when this happens is the washer jets
Wardy kindly ran VCDS and it came up with these errors, now am i right in thinking i need to replace the interior rear view mirror sensor,the wiper motor and my door lock microswitch? Ive spent a fair while on the forum to see if i could figure something out but im just getting confused lol, Oh and the trailor thingy is still connected, i will eventually get that completely removed,im not too worried about that
How do i remove the interior mirror and is the dealers the only place i can get this sensor from? i have read about changing the wiper relay from relay 192 to 377 to stop the auto sensing function but thats not fixing the issue for the auto sensing and also,is the wiper motor showing as faulty due to this interior sensor or is it just that the motor itself is actually faulty too?
The errors :
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000004979845
Coding: 41880F030004140000110D000000000000087F075C000000000000000000
Shop #: WSC 73430 790 00000
VCID: 71E2623D68B23BB
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 070409 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300610 054 0403
Coding: 00209069
Shop #: WSC 73430
4 Faults Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 45
Reset counter: 74
Mileage: 173374 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
ON
01517 - Control Module for Trailer/Towing Sensor (J345)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 88
Reset counter: 48
Mileage: 174280 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 9.55 V
OFF
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Reset counter: 74
Mileage: 173374 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
ON
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Reset counter: 74
Mileage: 173374 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F02050FC0085F96907C00
VCID: 830EB8F5C20EB9B
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 56
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 253
Mileage: 174280 km
Time Indication: 0
Date: 2000.00.00
Time: 21:13:20
Sorry for all the questions but this is really driving me nuts!!!
Isn't the interior sensors to do with the alarm system and not connected to the rain/light sensor?
Ian
Where is in the interior sensor? i thought it was built into the mirror next to the led?
Anyone got a How to for removal of the rear view anti dimming mirror?
this is a pic of the relays under the dash
which one is the wiper relay??
Well, the reason i cant find the same relay everyone else has in their cars is because, on a VRS or specifically,mine, the relay is built inside the wiper motor
Hence the fault showing as faulty wiper motor which is whats triggering the rain sensor to go all funny
£146 for the part and £81 to fit from dealers!!!
Any idea where else i can get a wiper motor other than the scrappys? and how do you remove the motor? is it quite hard?
I know the rear wiper motor is a dealer only part so I would imagine the front wiper motor is the same. You might find one on eBay though.
and im guessing the vrs and non-vrs are going to be different.....great,this should be fun.
Better off with scrapies or disable rain sensor
i was on the motorway yesterday and at 70mph in 2nd lane,my wipers just stopped working, and im pretty sure disabling the rain sensors isnt going to fix this problem
Sorry mate did not realise.
You may many faults due to only one afair. And because of this others "related" may show up.
then you have this
Freeze Frame:
Fault Priority: 2
Fault Frequency: 88
Reset counter: 48
Mileage: 174280 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 9.55 V
OFF
ON
OFF
OFF
Something must have happened for you to have 9.55 V.
Raining?? water may have entered somewhere!!!
Edited by alberg
hi Have you checked the LAN comunication wire from the wiper motor back to the onboard supply unit, its the purple wire? have had this problem before so it will be best to check this before throwing any parts at it.
Check for the rear washer pipe having leaked all over the towbar controller - it is mounted on the N/S/R wheelarch behind all the boot trim. A short here can cause all sorts of issues - I recently lost my front washers, rear wiper and rear washer because of a very slight leak here shorting something out and taking out the relay on the CEM - the bottom right hand relay is for the rear wipers, washers (front and rear) BTW.
sorry im confused? the towbar is causing my wipers to go loopy?
And how do i check the wire from the motor? is it easy to get to? Any pics please :)
andyvee, the washers work when the wipers are going crazy but the rest of the functionality on the wiper stalk completely stops working
Its getting worse and worse now, and this might sound weird but it happens more often when i turn right? turning left seems to calm them down, if not, completely stop them?
im going to check the rear washer pipe but how do i access the lan communication wire from wiper motor back to onboard supply unit?
I read that before, turning the wheel caused a short in the stalk and the wipers went all bonkers.
Don't remember where I read it, or a fix...sorry...but it's worth looking at the stalk!
  • 9 months later...
Did you ever find out the problem as I have the exact same problem with my wipers, also similar fault codes with the rain sensor, wiper motor, local data bus and 01044 control module incorrectly coded.
