Sub grounding point help
Hello all,
I'm after a solid grounding point for my sub in my 2006 Fabia vRS. At the moment i have it grounded behind the pasanger side rear headlight. Is there a better place to ground it as i think its casuing my EML to come on?
Any help much appreciated. :)
ilmor
Edited by ilmor
If you pull up the boot carpet and the side paneling on the left (as your looking in the boot) there should be a black wire in its own what will be bolted with a 10 mil bolt and that's your earth cable... That's what I've done and mine is fine.
Hope that helps buddy :)
Hope that h
Sent from la-Brom's iPhone...... Peace out, A town down.....
Cheers pal ill have a look tomorrow :)
ilmor
I always go for the seat belt buckle anchor.
I tried this, however the loop on the grounding wire isnt wide enough to allow the bolt to go through. :(
ilmor
I always use 4awg on my amps and you can get the right size connector for them.
