Skoda Felicia 1.3Mpi 1999 won't start
Hello all,
I am new to the forum and was wondering if any of you knowledgeable members might be able to help with my problem. My wife has been given this car by a friend who has lost patience with it after many new parts and recent reconditioned gearbox. The latest problem was that the engine kept stopping for no reason ( the last time on the M62 at 60+ mph). I have done a diagnostics test and there were 5 faults listed :-
00525-135 Oxygen sensor sporadic signal - too low
00537-141 Lambda regulation - sporadic lower stop value
17978-163 Engine start blocked by immobilizer p1570
00522-030 Engine coolant temperature sensor - open/short circuit to positive
00513-155 Engine speed sensor(G28) - sporadic implausible signal
I have replaced the coolant temperature sensor and I don't think the Lambda sensor faults would stop it starting. The immobiliser issue was caused by me (I think) useing the wrong key. I have also replaced the speed sensor( hall sensor). After doing all this I cleared all fault codes from the ECU and tried to start the car again, but no luck. On going back into the ECU diagnostics I am now only getting :-
Has anyone any idea as to what I can try next?
Many thanks in anticipation
John
Welcome. Can't help in your specific query but drop it in the Felicia section where someone more knowledgeable will be able to help.
Hi and welcome aboard.
Thanks Coops, I have now posted in the Felicia section.
