Columbus RNS 510 & an aftermarket TV Tuner
Hi all
I have just installed the Kufatec - IMA and Ampire DVBT52 TV Tuner into my car. All I need to do now is get the RNS 510 to accept the TV. In the MEDIA->VIDEO-> screen the "DVD button is highlighted but the "AV" and "TV" buttons are greyed out and wont activate.
The Documentation explains that --If the navigation unit has a software index higher than 522 the CAN-Gateway needs to be coded to TV tuner.
My Index is alot higher as the car is fairly new! I have been told that The Can Gateway 19 needs to be altered so that Byte 4 has Bit 7 ticked.
This does not work for me as the new coding is rejected !
My spec is
COLUMBUS SAT NAV RNS 510
Delivery Part No 3T0035680E
HW Version H61
SW Version 3984
Anyone suggest from experience an alternative Byte -Bit combination?(have also tried Byte 03 Bit 4 with no luck)
Am I right in ticking the TV Tuner box under Installation List before I alter the coding ? Tried ticked and unticked and coding change is still not accepted !
Get the message "Code rejected error 22 Conditions not correct or request sequence error "
I have my WSC, Import, and Equip No entered so this is not the cause !
Unfortunately there are no drop down help lists and tick boxes with my Can Gateway during long coding ?
Any Help would be Appreciated!
Ignore those instructions which tell you to switch a specific Byte/Bit, instead you may want to post a complete scan so we can take a closer look. If you want to give it a try, check the "Installation List" button once you've accessed [19 - CAN-Gateway] to enable/disable certain new modules/components. ;)
Thanks for replying Theresias !
I will post a complete scan tomorrow after I have done one in the morning !
Hi there !
2 scans completed 1st with tv installation in Can Gateway box unticked 2nd with box ticked !
Wednesday,25,April,2012,11:28:09:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61
VIN: TMBCT61Z0C2121348
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 NJ HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 8813
Revision: --H43--- Serial number:
Coding: 00114034032501080000
Shop #: WSC 73430 031 00090
ASAM Dataset: EV_ECM16TDI02103L906023NJ 003005
ROD: EV_ECM16TDI02103L906023NJ.rod
VCID: 7BF1F3DF4125
No fault code found.
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B201C092400FBC80E04E890210091340000
Shop #: WSC 73430 790 00090
VCID: 7BF1F3DF4125
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 AB HW: 3T0 820 047 AB
Component: AC Manuell H19 0502
Revision: 00001010
Coding: 0000000003
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_SK35.rod
VCID: 6FE9D78F055D
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 085 L HW: 1K0 937 085 L
Component: BCM PQ35 B+ 110 0651
Revision: 00110 AC
Coding: 48000AB8A00508904008008011000024430000AE420081605CC4C7000041
VCID: 387B2CD33093
Subsystem 1 - Part No: 1Z2 955 119 D
Component: Wischer 11121 26 0601
Coding: 00D7B7
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32901134801821
Coding: 10800E
Shop #: WSC 13765 790 00090
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000.rod
VCID: 33611BFF29F5
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q8 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2UJK7+
Coding: 0020792
VCID: 3D753DC71FB1
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AG HW: 5K0 953 569
Component: LENKS.MODUL 015 0140
Revision: FF010040 Serial number: 20120102802015
Coding: 4080140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: N/A
VCID: 72EFDEFB166F
No ASAM data for: "EV_SMLSNGVOLWSXS" (SK35)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 S HW: 1Z0 920 943 S
Component: KOMBI H05 0607
Serial number: 00000000000000
Coding: 410A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 499D59175B79
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 151211F2000675
Coding: 351303
Shop #: WSC 12345 123 12345
VCID: 3B7133DF01A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EADF469BBEBF
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 E HW: 3T0 035 680 E
Component: RNS-MID H61 3984
Revision: AB001001 Serial number: SKZ6Z7M5003066
Coding: 00000202000100810000
ASAM Dataset: ------------------------- ------
VCID: 326F1EFBD6EF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0131700
VCID: 489B5C134073
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 69 3301
Revision: 00H22000
VCID: 356525E72781
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131700
VCID: 47995F2F4D6D
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 326F1EFBD6EF
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030B185A
VCID: F1ED51F79369
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
End ---------------------------------------------------------------------
2nd
Wednesday,25,April,2012,11:33:34:10074
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 57 61
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Cannot be reached 1100
VCID: 7BF1F3DF4125
Revision: 00H31001
VCID: 7BF1F3DF4125
Revision: 00001010
Coding: 0000000003
VCID: 6FE9D78F055D
Revision: 00110 AC
VCID: 387B2CD33093
Coding: 00D7B7
Coding: 10800E
VCID: 33611BFF29F5
Coding: 0020792
VCID: 3D753DC71FB1
Coding: 4080140000
ROD: N/A
VCID: 72EFDEFB166F
Coding: 410A01
VCID: 499D59175B79
Coding: 351303
VCID: 3B7133DF01A5
1 Fault Found:
00467 - TV Tuner (R78)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 2008 km
Time Indication: 0
Date: 2003.14.12
Time: 11:28:43
Coding: 000000
VCID: EADF469BBEBF
VCID: 326F1EFBD6EF
Coding: 0131700
VCID: 489B5C134073
Revision: 00H22000
VCID: 356525E72781
Coding: 0131700
VCID: 47995F2F4D6D
Address 56: Radio Labels: 1T0-035-680.clb
Component: RNS-MID H61 RNS-MID H61 39843984
VCID: 326F1EFBD6EF
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 57: TV Tuner
Cannot be reached
Coding: 030B185A
VCID: F1ED51F79369
Thanks for looking
Bummer. I'd love to help you but since you decided to use a pirated version of our product that isn't gonna happen.
Oh dear ! Bought it on Ebay as a registered version! Paid quite a bit !
Thought I was getting a cast off! I'm Pretty new to this game !
