front window
Hi, just out of curiosity, but is there ment to be a rubber seal that go's around the frount window screan at all on the octavia??
Thanks..
I haven't on my 56 plate pal.
Sent from my BlackBerry 9790 using Tapatalk
hmm, thanks m8, it just seems odd that there is not one, as you may see that you start getting grean moll arond the outside of your window, hens you would think there sude be one....
No you don't have a rubber seal around the windscreen as the Octavia, like most other cars nowadays has a bonded in windscreen, mine also has a bit of green mould around the lower edge of the windscreen.
Ian.
still say it's odd tho, if you tape all it up you get no wind noise at all when doing 70mph or more!, awell thanks any way chaps.
