Login Code
Where can i find a security access code to enable cruise control?
Matt
IIRC, it's 11463
Correct
So how did you find that out fellas? is it for all 6y fabias?
It's for all VAG vehicles near enough, only changes for long coded vehicles.
Login code for ABS systems is 40968
thank you very much :)
fitting cruise control. tonight then. do you run a wire straight to the ecu like on fabia-vrs? or is there a plug/ working to splice into closer?
