Will a seat Leon cupra r solid flywheel fit a mk1 Skoda fabia Vrs
Been offered a very cheap solid flywheel wheel out of me mates cupra r due to him writing it off
I am here: http://tapatalk.com/map.php?5qjov1
Well, both should be 02M six speed. Post a picture of it as it might be possible the bolt pattern to bolt it up to the engine is a bit different. It also might not work with your oem clutch plate/housing due to width.
Put both ya reg numbers in eurocarparts and see if it gives you same part number.
Or there this one out of a fabia 54 and mine is a 55plate would there be any difference
I am here: http://tapatalk.com/map.php?3fh4wl
The spacein on the holes look different but then again it may b the picture measure the spaces between the holes
the holes look about right to me,the hole at 25past which I suspect you think is wrong will most likely be a locating dowel hole
