Cambelt Service
Idiots mate.. it states in the techincal bullitin when fitting water pump's to allow the pump to turn over then check and top up accordingly.. that and it's common knowledge for techinichians (well most) so they have made the error of not carrying the job out to the standard required by skoda. *TUT TUT*
more to my amusement how they have explained it to you as if topping up the coolant isn't common practise! When any water pump fitted to any vehicle should follow the same procedure. It comes down to somebody clearly half asleep with only half a brain cell working :)
What technical bulletin is this? Never seen a Volkswagen Group bulletin telling you to allow the water pump to turn over?...and I have seen a few!
This vehicle was rushed and didn't go through the quality control procedure correctly!
I would be asking for a replacement spring clip and boost hose though!!
