Audi RS2 front brakes
Hi,
I might buy a set of Audi RS2 front brakes with 323mm rotors CLICK.
My question is will they fit or will i have to buy adapters.
What will be the minimum wheel size? 17" et35 will work?
You would need to buy the carriers for those calipers as well.
This is a picture of one caliper, i'm guessing that i have my finger on the carrier? sorry for being a bit of a noob...
Also will they work ok with the master cylinder?
Edited by PaulMIG
That is the carrier but I'd be very surprised if it lined up with an Octavia.
As said the hub will probably not have the bolt holes in the right place for those carriers. If you got the measurements though you could probably get a fabrication place to make you up a couple of carriers
