Interior light not fading out when doors are closed ?
Hi all got a slight issue, its only just started happening but the interior light will not fade out in the front the rear is still fading. The front just stays on unless you manually turn it off.
As for locking the car the rears fade but the front just go off whereas they used to fade out does anyone have any idea what could be causing it .
Many thanks . :sweat:
The same thing started to happen to me.
Completely the same as described.
Also when locking the car front light will not fade as before, but just goes off instantly.
I know that on some cars there can be a problem with the switch in the doors responsible for turning on and off inside lights, but then rear light would not work properly and here thats not a case:(
Is there anyone one out there that can shed some light on it PLEASEEEEEEEEEEEEE ?
Does it happen to all bulbs in front or just the middle one.
Change the middle bulb from the front to rear.
all the front bulbs . cheers
I had exactly the same on mine as well although I never found what the cause was as after a couple of months it went back to normal, curious to know if anyone managed to fix it and find what was causing it?
John
fixed now cheers it went back to normal, local Skoda dealership were bamboozled aswell !
