fooked tyre lucky really
my drivers side rear had 3 screws in it all different sizes and tyre was flat but lucky skoda gives you the spare wheel tyre the same size wheel 16" so swapped spare wheel tyre over. :thumbup: anyone know where to get a single wheel from and how much it would cost? or do you have to buy a set? ta vikki
Have you nakered the rim ?
As i would have thought you just needed a new tyre.
New alloys are
i just need a tyre for my spare wheel as there is no tyre on spare wheel. tyre is on the vrs skoda alloy as it is the same size as the normal tyres which are 16" .so now have no spare wheel tyre.this is confusing me help :confused:
Ah ! I C you moved the Tyre from the spare to the Alloy.
So U now need a tyre for the empty rim sitting in the boot ?
is that correct ? ( lollipop for getting it right :) )
yes :D ( have 2 lolipops ) :thumbup:
www.mytyres.co.uk
Or even your local Kwik-Fit
please go anywhere else but Kwik ****
Ok, local scrappy then :P
Exactly, because "....you can't get thicker than a Kwik Fit Fitter" - as they used to say!
I'd go with My Tyres too, although you do have to pay a surcharge for just ordering one tyre. Should still be cheaper than anywhere else though.
Then get a local garage to whack it onto the spare rim. Or there's mobile tyre fitters listed on the My Tyres site.
Steve
I had the exact same thing!! Now running the spare tyre on the alloy - a screw in the DSR tyre!
DSR? :confused:
Steve
DSR? :confused:
Driver's Side Rear?
Chris
Yes, Driver's Side Rear - thought it would be clearer to most than OSR.
:rofl: Typical, you see I would have known what you meant with OSR! :)
Steve
