bonnet lock
hi guys
need help took lock off to service it and check the micro switch put wire back on the way i thought it went closed bonnet and now can,t get unlocked so need help on how to get to the lock help
hi, the bonnet lock doesnt have a micro switch?
which end did you remove, the bonnet end (at the mechanism) or the end at the handle in the drivers foot well.
If you removed the bonnet end, you may have to break through the grill to reconnect it.
If you released the pull handle end, then you need to take it off again, make sure the collet sleeve is located in the pull housing and the ball end is in the holder so it holds the cable in place properly.
cheers for the reply it,s at the bonnet end there,s a switch for the alarm on it
so did you disconnect the actual wire mechanism that goes to the bonnet release catch?
if you did, i think you will need to break the grill infront of the catch to manually release/pull the arm.
