Do bora front and rear bumper trims fit octy
Im thinking that bora bump strips for the front and rear bumpers may be a straight swap with an octavia?
Anyone know?
front deffo not as the vrs trim has a cut out for the number plate.
Ah bummer! Thought i may be able to raid a broken black bora for its trims :o
Are you painting them or has someone pinched yours?
No i removed my door trims to be faced with bubbling paint!
As id used a heatgun to remove mine they were curly so no use to put back on
I thought if i could find a black bora being broke i could pinch all the trims, and it would be painted black rather than horrible faded plastic :(
You can always trim them to fit.
My fabia has mk4 golf bump strips on it's doors. Only had to trim 8 mm of the fronts to fit.
I found that the door strips can be manipulated back to perfect!
Not if one has binned them :(
