where are front airbags crash/impact sensors
Tryin to find these sensors on octy vrs,
Also I pluged in radiator wires, coolant temp sensors, aicon rad wires but still got 2 or 3 plugs hangin down, is that could be them or something I got missing on the car?
Take a píc then i will tell you
I will mate but in 3 weeks time as being home for that time so no acess to the car
The sensors for the front airbags are inside the airbag control unit under the dash.
When you get back, for each connector, post the number of pins/wire colours and I can tell you what it's for
I took few pics.
Any idea where they going to?
There for you 2 fans on the front!!!
Those wires go to the fan controller. Looking from the FRONT of the car, the fan controller is located just to the right of the fans, below the level of the battery plate.
Cheers guys, quick reply, I love that forum
I will hav a look when come back to work
I had quick look today and my fans are already connected with plugs, any other possibilities what that could be?
Those ARE the wires to the fan controller. Follow the fan wires back, through the first set of connectors.
I will take a pic in a bit to show you buddy its simple to find ;-)
It's underneath (or should be lol) the battery box, under the metal tray.
Can't find any good pics on google, but search for "J293 Fan control module" and you'll see what it looks like. Both of the loose connectors go into it. The module also controls the AC compressor, so that won't work either.
Will have a look, possibly could be that
Dont worry, its little damage, friend didnt stop and finally stopped on towbar so bumper/ rads been cracked/leaked so I belive that module must be there as even fans not even touched
I ll give u shout when I check it after weekend
when you come to get the bits i will show you on my shell buddy !!
any idea's when you wanna pop over ?
