error codes
hi all just scanned the car got 3 codes but they,er not in the book they are 17564 17569 18062 car is 1.9 tdi elegance 2001 model any help would be appreciated
cheers
stu
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
17569 - Manifold Temp Sensor (G72): Open or Short to +
18062 - Please check DTC Memory of Instrument Cluster
If you clear them, do they come back?
If you fix the first 2 then the 18062 should clear
will clear them and check again cheers
