Fault codes after replacing electric power steering pump on Fabia
Hi Guys!
I'm just wondering whether anyone can help me. My electric power steering pump went wrong on my Fabia 1.4 X reg about a month ago. I bought one from the local scrapyard. Unfortunately they couldn't tell whether it was in working order or not. I replaced it and guess what it didn't work. So before I have returned it I was told that I should check all the wiring because quite often it was not the pump which fails. I disconnected the ECU and the instrumental panel and checked all the wiring between the instrumental panel and the ECU, ECU and the pump and between the pump and the instrumental panel. Everything seemed ok so I reconnected everything and realised that from that moment I couldn't even start the engine and four more fault codes appeared on my fault code reader but on the instrumental panel only the power steering pump sign showed. The codes are the following: 18044 missing message from air-bag controller, 18058 missing message from instrument cluster, 18045 missing message from electric load, 17978 engine start blocked by immobilizer. I double checked everything and everything seemed fine. I returned the pump to the scrape yard and I bought another one from ebay which has been tested. After I have installed it the power steering pump sign disappeared but I still couldn't start the engine and the four fault codes still exist. Any idea? Thanks
Have you cleared the codes and see if they come back. I changed my pump last month and recall all sorts of codes but I cleared them and they didnt come back.
Also doesnt a new pump have to be coded to the car, I had my pump repaired/re-built so it nothing was actually changed in it.
Hi
Thanks for your reply. Yes, I cleared the codes and they came back. As far as I know the pump doesn't have to be coded to the car.
