what lowering springs for fabia 1.4 mpi blackline?
Hello,
Im looking into getting some lowering springs and ive been looking at hundreds on ebay and im just not sure what ones fit, i was just wondering if anybody had already done this modification or if anybody out there knows?
A link to the correct ones would be a great help
Sam.
  • Sponsor
What drop are you looking for?
Damian @ DPM Performance
im looking for a 30-40mm drop.
Just springs? Eibachs are probably your best bet, or H&Rs. Any more than 40mm (some would say 30mm) and you'll need different dampers, at which point it makes more sense to pick up cheap coilies - unless you've got plenty of cash to buy midrange coilies at which point it comes out at around a similar level to springs and uprated dampers.
ah ok mate cheers, will springs that say they fit a vrs fit a non vrs aswell?
Nope - different weight ratings over the axles. The 1.9 TDI engine in the VRS is a lot heavier than a 1.4.
DPM do JOM coilovers for not that much more than you'll pay for springs but remember to check with your insurance company how much they want to charge you for the modification, all it takes is some muppet to crash into you and the assessor will spot non standard suspension quite easily.
