Air Con Issue
Hi
Was Wondering If Anyone Has Came Across This Problem Before
I Have 2006 Octavia 1.9 Tdi Bkc Engine The Problem Is The A/C Only Works Intermitted And What I Mean By This, Is The Car Only Starts To Pull Down To 4 Degrees When The Engine Coolant Fans Kick In, Both Fans Kick In And You Get A Blast Of Cold Air As Soon As The Engine Fans Kick Out Ac Drops Off (When The Engine Coolant Is Below 104 Degrees). I Have Had The Air Con Re-Gassed Pressure Tested With Nitrogen And Tested Ok When The Fans Do Run The Gauges On High And Low Side Of A/C Reading Correctly Which Means Composer Is Working.
Have Also Check the Menu in the Climatronic Controller 19 /4 and Shows Correct Engine Speed Also Have Checked For Faults in 08 A/C Control Units No Faults Nor Is There Any Faults in Any Other Control Unit
I Am Begging To Think the Small A/C Fan on the Rad Is To Blame
Ant Help or Thoughts Would Be Great
Have you had the system re-gassed?
Kwitfit will do it and guarantee it, or if they find leaks wont charge you unlike others
He says he has 5th line down
yea it has been re-gassed
also have checked power supply to comprosser all ok 12 volts switching as econ butoon is pressed
