Front strut brace
Hi guys im looking for a strut brace wheres best to buy from ? And is there different models
Part Number: 6L0 071 710 from any Seat dealer or Trade Part Specialist
Made from steel and comes in red. About 60 Pounds last time i checked (Sorry this stupid keyboard doesnt have a pound sign)
Forge front Strut brace - Available from Forge or other places like DPM Performance
Made from lightweight alloy and comes in a polished finish and costs around 70 pounds
Personally id spend a bit extra and get a Whiteline Rear ARB
I wanna get both are the struts simple fits or do i have to relocate things ? Cheers for your reply
from what ive read the forge uses all of the screws on the top mount, whereas the seat one uses less i think!
Seat one is easier/quicker to install
im sure someone will confirm!
I wanna get both
Hopefully you mean both front and rear rather than both SEAT and Forge front ones! :D
Seat one just slots under the strut bolts - i think the Forge one does too but uses more bolts as biggy says
The rear one just bolts into the rear suspension and is clamped around the rear beam
no "relocation" of anything is needed
To clarify (as Pasty clearly has no idea :giggle:)
Front upper strut Brace - bolts onto top of front suspension top mounts
(SEAT Sport Pictured)
Rear Strut Brace - bolts between suspension turrets
(Forge pictured)
Rear Anti-Roll Bar (RARB) - Bolts onto bottom of shocks and is clamped to rear beam
(Neuspeed item attached to my Roomster pictured, but you get the idea)
HTH :thumbup:
I have the forge front strut brace, looking at changing to the seat one! The forge one uses all the bolts but is a pain to get on and off, It looks great but for me is a pain for when I had to change the air filter and I find it just usually gets in the way, plus when you need to undo the bolts to take it off the strut drops, not a problem with the seat one I assume, and also I found fitting it was a pain as tools were hard to get to the bolts
Thanks for the help guys does the rarb just fit straight on or is it a pain ?
RARB takes 30 minutes to fit :)
If you take your time...... :giggle:
Meh i knew what i meant :p
I cant find any sellers or prices at all :/
SEAT sport strut brace is from any seat main dealer or TPS. Forge items from forge or one of their resellers and the whitelines RARB from DPM, Awesome GTI or eBay!
