Intake manifold fault
I thought I had been doing a little too well and now at nearly 80,000km my first fault . . . or not as it happens - I suddenly have four faults which goes to prove that ignorance is bliss sometimes. The most important one and subject of the post is the engine fault but doing a faultscan revealed some more.
The Telephone one I can probably safely clear as it occurred whilst I was recoding the bluetooth module this weekend.
The CAN gateway one seems to have occurred when the car was last serviced which is irksome.
The driver-side wiper motor will need sorting out (is that UK driver side BTW?). Then the engine fault occurred on start-up yesterday after a fast trip back from the New Forest, I didn't notice anything wrong with the performance en route - quite the opposite actually - it was going like a dream. Any ideas on what it is?
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Not registered 0001
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 1Z0 907 115 AF HW: 1Z0 907 115 F
Component: 2.0l R4/4V TFSI 0010
Revision: AAH15--- Serial number:
Coding: 0203000C1C070160
Shop #: WSC 73430 790 00999
VCID: 79F3D73230C2731
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 16
Mileage: 76691 km
Time Indication: 0
Date: 2026.14.13
Time: 23:43:19
Freeze Frame:
RPM: 3004 /min
Load: 18.8 %
Speed: 120.0 km/h
Temperature: 93.0°C
Temperature: 17.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 48180ABAF05BB1C040080080110011E4437000AE626D8D60800540040000
VCID: 3261201E6D34409
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 30011 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 060210 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
1 Fault Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 186
Mileage: 72859 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.40 V
OFF
OFF
Term 50 Off
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K1020507F2
Coding: ED217F06000612002303
Shop #: WSC 61409 210 11563
VCID: 69D387724062C31
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 135
Mileage: 63654 km
Time Indication: 0
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 5N0 035 730 D HW: 5N0 035 730 D
Component: Telefon 009 0511
Revision: -------- Serial number: 35909603069361
Coding: 020100010100000000000100
Shop #: WSC 20268 012 20168
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SK35.rod
VCID: 2953C77248E2031
1 Fault Found:
9458193 - Control Module for Cellular Telephone
B1052 14 [024] - Open or Short to Ground
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 148
Mileage: 76378 km
Date: 2026.14.10
Time: 21:12:02
End ---------------------------------------------------------------------
Well the dealer seemed to recognize the fault immediately so I guess it must be fairly common. I will post up what happens in case anyone else gets the same.
It is a tumble flap motor fault, no big deal it has to occur a few times to put your engine check light on, it is to help idling, you can reset it with vagcom in seconds happened 3 times to me :happy:
Thanks for the info, very useful.. I will have it checked anyway as it is still under warranty and there is the wiper motor fault to sort out too. Now you mention it the idle has been a bit hit and miss recently. Started hunting a bit sometimes, hmm - I will know what to look out for next time.
Yeah, mine had this too a few months back.  Dealer did some sort of reset/re-boot and it went away only to come back again.  No arguments from them however - they replaced the whole intake manifold under warranty.  If you do some googling on that code its also not entirely uncommon on other vag products with the same engine.
Hope you get it sorted.
http://www.briskoda...._1#entry2745558
This isn't 'swirl flap' related then?
Every time I see an inlet manifold thread I shudder. My previous car suffered a swirl flap failure which was subsequently ingested by the engine causing an awful lot of damage.
These are referred to as tumble flaps and aid low speed cylinder filling and help produce torque.
You can perform basic settings with VCDS but if it keeps coming back you probably need a new flap motor.
  • 2 years later...
Sorry to revive such an old thread, but is just the motor a replaceable part or is it new inlet manifold time?
I had this and it needed a whole new inlet (comes with sensors)
I think I paid just shy of £500 in total
parts are
06J 998 907 B - Repair Kit - Qty 4 £21.00
06J 133 201 AS - Manifold - Qty 1 £282.69
The main issue I had was MIL on and revs would rise from idle once engine was up to running temp
