road Horn Polarity
Hi, new to forum so please be nice(ish)
In the process of fitting a siren unit to a 10 plate Octavia Vrs and looking for the following info:
1) is the horn positively or negatively switched?
2) if its positive switched then no problems as i can take a pulsed positive feed on horn press
3) if the horn is negatively switched then the siren unit I have will deal with this, do I just attach to negative side?
cheers
medix
Edited by medic999
Managed to answer my own question (after a fair bit of searching and head scratching)
- Road horns (octavia vrs 2010), 1 located each side behind front fogs, easiest way to get to them is to remove sump/under engine cover and the wheel arch and go in from underneath.
- road horns are positively switched
