electrical problem? Help!
Hi All
i got a fabia vrs on a 55 plate.
the other day i went to start the car as normal, there was electrical power (clock was showing), i put the key in turn it to the 1st position warning lights came up as usual. then tired turning it over as i normally do, but instead of starting, all the electrics died. they came back on after about 10 mins. then started and drove fine.
now if i try to start it quickly all the electrics die, if i turn ignition to 1 and then wait to start it, its starts fine most times.
any ideas???
Sounds like an ignition fault to me?
