Interior door handle parts
Hi,
I'm sprucing up my Octy mk2 as it needs some TLC. I've noticed in my Haynes manual that the door handle cover can be removed and replaced but no part number is given.
This is an aftermarket kit of the parts I'd like to replace: http://www.superskoda.com/Skoda/OCTAVIA-II/Octavia-II-interior-door-handle-covers-CHROME
But I really would rather stick to the original black ones. Mine are quite scuffed up from the previous owner, I think he chewed them or something.
Can anyone help me find the part number for original replacements, or black oem ones?
Thanks in advance.
I have a full set of black ones, available, changed to the chromed ones as they make the interior look better and passengers can see them in the dark
Removing them is easy, remove grill, undo the torx screw, using a solid thin piece of plastic gently leaver the whole handle and surround off, gently turn the handle assembly over and unhook the cable it looks like the same as used on a bike break cable, replace in revers order
Scrub last post I miss read it thought you where on about interior ones
Puts brain back in gear you where on about the interior ones
