auto lights
hi all
would it be poss to fit auto lights with coming home and leaving home thing
i have auto wipers and auto dim mirror but not auto lights?
If you have auto wipers then I believe that means you have the light sensor so all you should need is the headlight switch with the auto setting.
You should be able to enable ch/lh lights with vcds without any alterations.
thank you where is best place to get switch
