intermittent air conditioning
Hi people, my air con started to play up last week, ive taken it to have the gas recovered and regased, replaced the high pressure sensor, still no joy
just done a scan of the car and have the following info
could someone place some light on this because i was thinking its the compressor
should i remove the fault codes and rescan, some could be old ones maybe ??????
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,06,July,2012,16:16:06:32803
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z Mileage: 125940km/78255miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: CUSTOM-CODE HW: 03G 906 018 EL
Component: JBS PPD DPF G OFF
Revision: --H32--- Serial number: SKZ7Z0F3813160
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 234FDE58E2CED91
1 Fault Found:
005685 - Powertrain Data Bus
P1635 - 009 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 33
Mileage: 125781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:22
Freeze Frame:
RPM: 800 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 14.01 V
Bin. Bits: 00000000
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 73430 790 00000
VCID: 73EFEE1812AE091
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B7F06387A7E811
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004470798
Coding: 01880F030004140000110D000000000000087F075C
Shop #: WSC 73430 790 08192
VCID: 2B5F36788A1E111
Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 73430
1 Fault Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 16
Mileage: 125781 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0TKD9Y
Coding: 0020788
VCID: 3D7B0820646A8F1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Shop #: WSC 24066 576 88149
VCID: 74EDED0417A00E9
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 E HW: 1Z0 920 912 E
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0F3813160
Coding: 0003401
Shop #: WSC 28051 576 92332
VCID: 37771A084656A51
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 16
Mileage: 125781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:30:44
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069130043
Coding: 3D3F034007001303
VCID: 2C5D35648F10169
3 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 32
Mileage: 43016 km
Time Indication: 0
Date: 2000.00.00
Time: 13:11:57
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 43016 km
Time Indication: 0
Date: 2000.00.00
Time: 13:12:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 125781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:24
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0944
Coding: 0000756
VCID: 387519344B48AA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
VCID: 356B10005C5A571
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 18801A085283007F3F04850540085F96907CA0
VCID: 830F3ED8C20EB91
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 24066
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 16
Mileage: 125781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:25
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 240
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 39731C307042B31
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End ---------------------------------------------------------------------
anyone ?
no air con at all now, VCDS says the pump is turning and with a load of 1.2n of force.
The fault codes relating to the air con all look recent, have you checked all of the fuses? it sounds a bit like power is missing to something, I take it the little LCD's still come to life on your climatronic unit and the fan still blows?
Also I wonder if the G266 sensor has anything to do with the air con? (Maybe someone that knows more can chip in here) as you are getting a fault on that.
Radio/infotainment faults look like old faults, I'd be tempted to clear them all down and see what reoccurs. I do know that in some cases once the fault is fixed the systems still don't work until the fault codes are cleared.
Hi anddenton, I must admit that I was pulling fuses to check them,
Just one thing I've noticed is that when the comp was running it sounded louder than what I can remember from befor. Maybe the comp shaft has snapped .
I go rescan now :p
mines intermittent too. it worked for 3 years, not for the last 6 and a half years, fingers crossed its just a glitch...........bit too aircony for me,,,, ill just wait
Edited by Lofty79
But how do you put up with steamed up windows lol. Does my head in lol
Can anyone get some live data on the "08 auto HVAC" showing compressor load etc, mine is saying 1.2n load at tickover.
Please :)
Check the wiring and power supply the the AC compressor and the like.
Evening all, been playing with the Vcds watching the air con pump load / amps to the pump / rad fan speeds, ok the air con will run when the temp is set to low eg feeding the compressor with 0.7 amps ish, when I select Eco mode compressor load / fan etc all zero off then when I turn it back to auto vcds says its running but the comp load is only 1.2n for sometimes upto 3 mins then it go's to 4.8n (blows cold)
Can I assume it's the solenoid in the end of the pump not working correct (sticking etc)
Oh and turned the radio off in the can gateway, did a rescan and no faults ;)
Cheeze - there is 12v feed to the ac pump with ac on and 3.7v with ac off (Eco mode)
Rgs Martin
