Bluetooth Bolero phone number problem
I was trying to code another members retrofitted BT module (5K0 ... D) to his Bolero (has a FL CAN) and while it connects and makes / receives calls, the Bolero displays lots of random characters and muddles up the numbers with different contacts.
Is this an issue with the phone address book or with the coding?
I read about something similar on here, but cannot find it again now and I don't remember a solution.
Can anyone tell me what I have most likely overlooked or need to change.
Thanks.
I have vague recollection of somebody having this issue when they had non english characters in the address book - acutes, umlauts etc
Sounds like a very similar issue.
I have tried to find the thread again, but can't seem to find it. Anyone know where it is or what the problem/solution is?
Did you sort this in the end?
ACSC
It has been resolved (mostly) by changing the Bolero unit for a newer one as the old one was not compatible with the newer BT module.
I guess an older BT module wod also work!
The empty boxes either side of the BT symbol on the Maxidot display are still there, but this seems to be an issue with the Maxidot itself: the dealer was not able to update the software on it
If you want to know more contact styler67 as its his car.
