passenger door problem?
my passenger door work lock if the door is open.
that's when i use the driver to lock is this normal or is it a fault?
i realised tried the door after i locked it meaning most of the time the passenger door has been open thankfully no one has tried it :whew:
What
Sent from my HTC One X using Tapatalk 2
Lock via the key hole on the door?? Dont you use your key fob to lock?? with the key fob the passenger door will lock, if you have shut drivers door and passenger door open, it will lock when you press button after the door is shut, indicator flashes aswell to confirm lock
I don't have remote central locking.
Well if you have central locking then its playing up or just doesnt work lyk that
