Wet floors in my Octavia Estate
The heavy rain seems to be getting into my Y reg Octavia Estate. The driver's side has puddles in both the front and the rear. I have looked aaround for drain holes and consulted my Haynes but can't find anything.
I would be grateful for some help.
T
Check the scuttle panel under the wipers the drain holes can block up. Does Yours have a sun roof?
Thanks Ref_. Not sure what you mean by the scuttle panels. I have opened the bonnet and look under the wipers but there did not seem to be anything accessible there. I looked though a grill and there were some leaves but I could not get at them.
T
Under the plastic trim, they can be hard to remove, if you take the long rubber seal off you should be able to lift the plastic trim up enough to see. If not you may have to remove the wipers and take the whole trim off, think you lift it slightly and pull but not 100% sure m8
