octy vrs calipers
will the front and rear calipers from an octy vrs fit onto fabia carriers? or is it the carrier that allows the bigger disc?
probably not as why would everyone buy the compete 312's?? I could be wrong mind..
Need the carriers for the fronts but I *think* the rears use the same carriers. Not 100% on the rears though
Different rear carriers, disc is wider and bigger at rear.
Fronts are not only bigger they are a different type of caliper.
All in the 312mm fitting guide
