Fake cat
Any one thought of building a fake cat over there downpipe for new MOT?
Was thinking get 2.5" then build a fake cat over it and jobs a goodun"
Just smash the internals out of your cat no? Cut the cat out, get a hammer And a big screwdriver and get hitting
Cat test only for spark ignition cars, so no need on my diesel.
They'll still check the presence of a cat/DPF though.
i stand corrected..
looked this morning + although it is mentioned in the exhaust section not emmisions section (so compression + spark ignition testing rules not relevent)
it does state>>>>>
NOTE: diesels dont qualify for a 'full cat emmisions test'
hope that clears it up - my bad :drunk:
So do I need a cat for my MOT or not now still a little bit confused was thinking of cutting of can n outing straight pipe n swapping over pipes for MOT but can't have 2.5 bore then can I ?
sorry.. the middle section explains the vehicles the rule applys to + the right section gives you the failable items..
as diesels dont qualify for a 'FULL cat emmisions test' the 'lack of a cat where one was fitted' failure does not apply.
so in short having no cat on a diesel is not a fail..
i will ring VOSA at some point for a clearer explanation ofthe 'full cat emmisions test' to be 100%
this is a new rule hence it has a black bold line 2 the left of it.
confusion cleared up.. ish lol ;-)
just been on the phone to VOSA + you can de-cat a diesel + it will not fail on the fact it has no cat...
although excess 'dense' smoke is a fail regardless of whether it passes emmisions.. so it would be wise to give the car a good thrash pre MOT to clear out the pipes ;-)
No they won't.
No. I had a decat pipe made up for mine with a flange @ each end to bolt in and out come MOT time. Guess where the pipe containing the CAT has been for the last 5 years?
Correct. Slowly corroding in my garage.
take it to the scrap man ;-) i got £40 for mine :-)
Thanks for cleaning that all up for me
TPS downpipe on to order list then ;)
No they won't.
Even on the new regs?
this thread was refering to the mk1 vrs pd tdi
the newer diesel stuff from late 2008- has a stricter diesel smoke test to pass so although removing the cat/ dpf is not a fail in itself. it might not be able to pass the smoke test (emissions) without the dpf. i have not tested a dpf diesel that has had it removed yet.. but i know some of the earlier diesels wouldnt pass the 2008- test even standard with cat and no remap as its alot stricter
No, I seem to remember reading that the new MOT regs will check for the presence of a cat and/or DPF, hence companies gutting the DPF rather than just putting a straight pipe in? Or was that from the "ideas" for the new regs?
iv attached a pic of the failure further up the page.. there is a new section highlighted for cats not being fitted (no mention of DPF)... but... this does not apply to diesels as they do not req a 'full cat emmisions test'.. to be 100% sure i rang VOSA and they confirmed it does not apply to diesels. this was printed off the MOT computer today so is bang upto date (and i rang VOSA today also).
Hmm... just checked, yeah... check for presence of cat only!
Nevermind :D
also the reason companys gut the DPF is so the sensors still read.. therefore elliminating running problems.. engine lights + no need for a remap
Just had my vrs in for it's MOT on Friday just gone (13th) at a Skoda dealer and it went straight through with not a mention of a missing cat (turbo back milltek with decat) !
You DO NOT need a cat for it's MOT !!!!!!!!!!!!!
please read thread before posting with '!!!!!!!'s' as stated several times already.. u dont need a cat for a DIESEL MOT.. posting random coments after only confuses an already confusing thread. thanks
Not really a random comment. He was just saying his past minus a cat. People will read the thread and get the just of it. No need to shoot him down.
Sent from "Ain't nobody got time for this"
point taken..
although 1 car passing its MOT is far less of a reliable indication of the MOT rulebook than... the MOT rulebook itself..
i know that although i had already chopped my cat out.. for those people who wanted to be sure it would pass before decating.. it would be better to read the actual test section further up to confirm 100%.
point taken..
It's also been said dozens of times that a cat isn't needed for MOT but yet people are still ****ting themselfs about having a decat etc !
I have got an emission printout stating the turbo limit is 3.00 whatever that means I'm not sure but pretty sure if it's over that it's a fail !!!!!!!!!!!!!!!!!
nowt to do with emissions m8 as stated above. the NEW fail that has come into effect from may 2012 only is in the exhaust section of the test.. (regarding the presence of the cat.. not whether it passes emmisions or not)
this however does not effect diesels (also stated above)..
the reason people are still ****ting themselves is because this rule is new + has never been in use before.. there was alot of talk about it before it came in.. and alot of confusion surrounding whether this applys to diesels..
i have cleared this up SEE ABOVE...
the NEWER diesels 2008- info which was a reply to BABS question is a different kettle of fish but DOES NOT APPLY to fabia vrs or pd tdi's. this is only for cars with a DPF from 2008 onwards.
i may have repeated this several times above. appologies for those who read it the 1st time
rant over ;-)
