VAGCOM flatus
Having scanned the Octiy to clear the Airbag warning light (After removing the battery for installing the amp and other radio bits) I thought I'd scan the rest of the car whilst I had the cable. Could anyone shed some light on some of these errors?
I'm guessing the overboost error is sticky VNT's in the turbo but not 100% sure as the limp mode comes and goes.
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 232.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000100
Temperature: -1.8°C
Bin. Bits: 00110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 232.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000100
Temperature: -1.8°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 232.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000100
Temperature: -1.8°C
Bin. Bits: 00110000
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
RPM: 3276 /min
Torque: 326.0 Nm
Speed: 111.0 km/h
Load: 78.8 %
Voltage: 14.29 V
Bin. Bits: 11000000
Absolute Pres.: 2233.8 mbar
Absolute Pres.: 2590.8 mbar
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 1764 /min
Torque: 136.0 Nm
Speed: 77.0 km/h
Load: 29.4 %
Voltage: 14.59 V
Bin. Bits: 11000000
Temperature: 41.4°C
Temperature: 40.5°C
Cheers :)
