fan staying on `
Just recently noticed once my car gets warm the fan seems to stay on till i stop the engine
I have a 57 plate petrol vrs
Has anyone else had this problem ? Thought it was maybe a dodgy switch ?
Isnt really causing me great concern as yet .
Davie
Does this seem to happen when you have your aircon on? Might be worth opening the bonnet and checking if both fans are running or just the one. I had to replace my aircon (smaller) fan last year as it had failed, but the failure meant that the larger radiator fan was running permanently when the engine was on.
I think I have also seen something on here to do with faulty switches that can cause the problem.
Happens in the hot weather as far as I know.
My CR170 odes the same when hot.
If they continually run fast, then you may have an aircon problem.
I had to replace a pressure switch on the a/c circuit earlier this year - thankfully is was not the compressor failure that some cars have suffered from.
'07 vrs petrol.
Ok i would defo say both both fans and running fast ! :sweat:
Ok found out why seems i had been running the a/c permantly i though when nothing was selected this was normall but after reading your responses i went and put it on econ and hence both fans stopped.
What a retard but something new has been learned " :blush:
Sorry guys but thanks !
