Fitted MFSW to FL Vrs but can't get it to work (and now I dont have CC or a horn!)
VRSPhil
Recommended Posts
Hello all
I've fitted a new FL vrs steering wheel to my 2011 vRS along with a new controller and wiring loom. Since fitting I have lost the horn and CC and can't get the buttons on the steering wheel to work.
I have numerous fault codes along the lines of CC open/short and basic settings missing. I have tried (and failed) to complete basic settings. I have tried (and failed) to tell the "steering wheel" module in VCDS that there is a MFSW. It just says "coding not accepted, out of range" when I try that.
There are no faults on the airbags and no warning lights. The adaptive lights still turn and the cornering fogs also still work.
Any advice would be great, im stumped!
Phil
Link to comment
Share on other sites
Had a similar thing happen on a wheel I fitted recently.
I assume the controller was s/h? if so there will be items enabled that need to be disabled.
I will post up the long code for you in a bit (it's on the netbook).
Link to comment
Factory fitted controller (MY11 Octavia vRS with manual gearbox)
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BL HW: 5K0 953 569 C
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101129301304
Coding: 5080140000
Shop #: WSC 73430 790 00088
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SK35.rod
VCID: 77F65E2BCED664C
No fault code found.
Replacement controller for MFSW - WITH WRONG CODING FOR MANUAL CAR (c/w DTC's thrown up)
Part No SW: 5K0 953 569 H HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: --X01--- Serial number: 20120121301625
Coding: F980A04000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_SK35.rod
VCID: 3D7A8C03AC6A8F1
6 Faults Found:
0516 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
335876 - Powertrain Databus
U0002 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
1140738 - Steering Angle Sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 17509 km
Date: 2016.14.01
Time: 01:50:06
Now with the correct coding:
Coding: 5082100000
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
So if you have fitted a replacement controller 5K0 953 569 H, you can try the long code 5082100000.
HTH
Link to comment
You...are a legend! Those faults look identical to mine, and I have got the H controller. I'll give this a whirl in the morning when I have the car again and report back. Thank you very much!
Link to comment
Of course he is :thumbup:
It took a couple of hrs to work out which code was blocking the buttons not working, along with the horn & cruise.
A couple of questions -
BTW do you have cruise ? If not you may need to switch it off as this code includes cruise activation.
When you have done this can you let me know of the right side thumbwheel & the bottom button on the right works on yours ?
Link to comment
I do have cruise. And I will let you know re the roller/buttons. I'm expecting them to operate the maxidot though, which I have not yet had fitted... I'll see what happens.
Link to comment
Ah in that case they probably will work as you intend, on Steve's car it had maxidot before, so the controls for that are on the wiper stalk, thinking out loud now Steve, but did I look to see if I could turn off the maxidot controls on the stalk?
Link to comment
Mine currently has the standard Trip computer which is controlled by the stalk buttons, however, I did notice there is a ticked option along the lines of "computer control via wiper stalk" so I wonder if disabling this could solve your problem?
Link to comment
Update - the above code worked (well the buttons work, and there are no faults. I didn't test the horn as its 12:30 :) thank you again.
Re the buttons on the right, the ticky box is byte six but I tried unchecking it and it stopped the wiper stalk buttons from working but didn't make the roller work. I'll have another fiddle tomorrow and update if I get it working.
Link to comment
Phil, did you see the table in the manual about what the roller is supped to do ?
As the instruction i found wern't clear if it was maxi dot or the Bolero where you were supposed to see the results. ( I take it you have the Bolero & not upgraded to sat nav - columbus)
Martin- Maybe we can try mine @ the meet ?
Link to comment
To be honest, I haven't looked in the manual. However, pressing the right hand roller in changes my trip between 1 and 2, or holding it resets the trip.... So it is doing the same as the reset button under the wiper stalk. Rolling the roller does nothing, nor does the lower button (back arrow?) on the right hand side. The top button changes between radio and media on the bolero and the left hand buttons all work as expected....
Link to comment
FYI - The manual says that the roller button is supposed to scroll up / down the menu, the back arrow is supposed to take you back up a folder, i suspect pressing the roller brings up the menu that you can scroll round.
Link to comment
  • 2 months later...
Thanks Phil,
I am picking up my new vrs on Friday and have been through the "you can't have a MFSW unless you have a DSG" what a load of rubbish, then it was " oh it is way to complicated to fit that"
Is it right that Shark can fit and code all this up?
Link to comment
  • 3 years later...
i retrofitted MFSW with paddles on my Octavia II FL 2011 Ambiente  model.  Also changed the controller to High line.  Steering controls and Paddles are working flawlessly. However i am unable to operate MFD on the cluster(standard cluster, not maxidot) using wiper stalk buttons or with steering controls. MFD is fixed on temperature display. I cannot change to any other display (Digital speed, avg. km/lt, distance, etc).  however Wiper controls are working in order.
Following are the vcds coding before and after fitting Steering module & MFSW
BEFORE
   Part No SW: 1K5 953 521 AE    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110412100022
   Coding: 4880040000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 70F7C6F3FAA3EA02EF00065-8024
AFTER
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   016 0140
   Revision: FF010041    Serial number: 20121009100661
   Coding: 009A140000
   Shop #: WSC 19460 666 12345
   VCID: 79E1FBE7A9D9AB4A58DEE39-802C
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 5E0 919 719 G    HW: 5E0 919 719 G
   Component: E221__MFL-PR6  H05 0130
   Coding: 830000
1 Fault Found:
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 54185 km
                    Date: 2016.05.06
                    Time: 02:15:02
What is this turn signal short to ground error.
Folks kindly advise how to make the MFD controls functional using wiper stalk or steering controls.  As far as i know streering controls for MFD work only on maxidot cluster. Since mine is a standard cluster, there should be some way to make wiper stalk buttons functional.
Link to comment
BEFORE
   Coding: 4880040000
AFTER
   Coding: 009A140000
   Coding: 830000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 54185 km
                    Date: 2016.05.06
                    Time: 02:15:02
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
