Tips on ARB Bushes Please
Hi,
Are there any good tips on changing the front ARB bushes?
I’ve taken one look at them and have no idea how your meant to get the bolts out without removing the driveshaft.
A spanner wont get bite, a socket won’t fit in and neither will one of them deep, bent spanner things.
Surely it’s not that hard? Am I missing something silly?
You have to put the front of the car on axle stands and then carefully jack the wishbone up (from under the bottom ball joint) to move the drive shaft out the way.
P.S. use a block of wood between the jack and the balljoint to protect the balljoint.....also by doing this it will lift the car of the axle stand on that side!
Now that is an intersting idea!
Thanks, I will give that a go tonight if I get chance.
