Key Fob Programming
How do,
I have now had the backdoor locks replaced on my Skoda and all is working fine, child locks are working again etc.
My only issue now is neither of my fobs work (they havent for ages). I have found instructions on the web as follows:
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure is the same, except you press the unlock button 2, 3 or 4 times for the different remote.
For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
But I assume to do this you need to have at least 1 key that works?
If I dont is it a trip to a proper dealer to correct?
No key doesn't have to work, mine never beeped but worked fine think its just for cars with alarms. Way I did it was to wind the window down with the key in the ignition, lock drivers door with key then press the button on the key in the ignition tool 20 seconds if that lol
Sent from my Galaxy S2 not a Crapple!
Hey, cheers for that, just been out to try this but nowt happens, no horn beep at all. Weirdlythe LED on the key fob starts to flash of its own accord sometimes but when it stops its still not doing owt...
You pressing the same button atleast 10 secs apart? Have you changed the battery?
  • 5 years later...
what to do when there is no second key
