Camshaft position sensor - P0343
Hi folks.
Has anyone had this error and tried cleaning the sensor body if its dirty, or is it pretty much a quick sensor swap with a new one? Sometimes struggles to start and just turns over.
Cheers,
Mine has this as an intermittent fault, can be a few days or every other journey. Never had trouble starting though
Sent from my Galaxy S2 not a Crapple!
Does the rev counter give a speed when you crank the engine but it doesn't start?
Not from what I can tell. The car has never cut out on the move, just when starting on occasion this occurs.
Edited by Liverpool-Lad
Cleaned the sensor (wasnt dirty anyway) with some IPA. Still the same problem so ordered a new one...lets see what happens now!
How hard to fit? And where is it? lol
c'mon mate that's easy....
ta taaa :)
Kool thanks for that haven't taken the plastic cover off mine lol
Thought it was under the cam cover for some reason!
I couldnt totally remove the cambelt cover but managed to get to it. Only 2 10mm bolts holding it on.
Many many of you have trouble getting out and putting back in the cambelt cover.It's so simple...you just have to tilt it to the back (of the car) and insert it.
On the TT forums are pages and pages with that :rofl:
I think I'll make a video
Sounds good. Tried that direction and just didnt seem to be enough clearance to remove it.
Oops, got stuck in traffic and engine cut out. Had to get towed home. New sensor in the post awaiting fitment!
