Vacuum pipework - on a diesel
right, I know a lot of the petrol owners remove various bits of pipework, so I had a look at my diesel.
From what I can determine the follow layout occurs:
vacuum pump -> brake servo (via rigid pipe across the bulkhead)
vacuum pump -> EGR control valve
vacuum pump -> Anti-shuddder valve
vacuum pump -> one-way valve -> vacuum ball
vacuum pump -> one-way valve -> n75 (turbo) valve
However my car isn't quite standard anymore:
- EGR blocked off
- Anti-shudder control arm is broken (my father dropped it on the floor)
Therefore I have re-routed my pipework to bypass the EGR and Anti-shudder valves, giving me:
To look like this:
The car has been running like this for a few weeks with no (apparent) issues.
Am I doing anything bad for removing these valves from the vacuum side of things (they still have their electrical connections).
Thanks,
Matt
Edited by mbames
I dont think so, it seems as though it will just cut down on chances for vac leaks. Do you not miss the anti shudder?
I do miss the anti-shudder, but it wasn't till a few weeks ago did I realise the previous repair had failed. The plastic plunger is no longer attached. We did try gluing it back together when it first broke, but obvious that didn't last.
I guess if I happened to be in a scrap yard and a replacement plunger unit was available I would fit it. However I have a feeling that detaching it from the rest of the EGR assembly is quite hard.
I have now done this and have very little pipe now. Just 1ft from vac to n72 t'd after non return to ball. Then 1 to airbox, 1to turbo. Find it alot better, very small Chance of a leak.
Currently all my pipework is still in place, just bypassed. But I might be tempted to remove it, and just leave the valves attached (and block the ends off so they don't get any dirt in them).
